OEM+ car styling is a popular trend among car enthusiasts who want to personalise their vehicles without sacrificing the quality and reliability of original equipment manufacturer (OEM) parts. It involves using OEM parts from other models within the same brand or even from different brands to subtly enhance the appearance and performance of your car.
OEM+ Car Styling Benefits
One of the main benefits of OEM+ styling is that it allows you to create a unique look for your car while maintaining its factory-engineered integrity. Since you’re using parts designed by the manufacturer, you can be confident that they will fit properly and function as intended. This approach also helps to preserve the resale value of your car, as it avoids the potential pitfalls of cheap aftermarket modifications.
Examples of OEM+ styling:
- Swapping wheels with a higher-end model: If you own a base-model car, you could upgrade to the wheels from a higher-trim level within the same brand. This can give your car a sportier or more luxurious look without requiring any modifications to the car’s suspension or body.
- Adding a subtle body kit: Some manufacturers offer subtle body kits for their cars that are designed to enhance the car’s aerodynamics and appearance without being overly aggressive. These kits often include front and rear spoilers, side skirts, and diffusers.
- Upgrading interior components: You could swap out your car’s seats, steering wheel, or shift knob with those from a higher-end model. This can improve the comfort and feel of your car’s interior.
- Performance upgrades: Some OEM parts can also improve your car’s performance. For example, you could upgrade to a larger brake system or a sportier suspension setup from a higher-performance model within the same brand.
Sourcing Parts from a Specialist Breaker
Most vehicle owners have a wealth of options when it comes to OEM+ car styling. By sourcing parts from a specialist breaker such as a Mitsubishi breaker or Toyota breaker, you can find a wide range of OEM components at affordable prices. Here are a few ideas:
- Enhance the exterior: You could add a front lip spoiler or side skirts from a higher-trim model to give your car a sportier look. You could also swap out your car’s mirrors or door handles with those from a different model.
- Upgrade the interior: Consider replacing your car’s seats with leather seats from a luxury Mitsubishi model. You could also upgrade the steering wheel or shift knob to a sportier design.
- Improve performance: If you’re looking for a performance boost, you could source a larger brake system or a sportier suspension setup from a higher-performance Mitsubishi model.
When sourcing parts from a breaker, it’s important to make sure that the parts are compatible with your car’s model and year. You should also inspect the parts carefully for any damage before purchasing them.
OEM+ car styling is a great way to personalise your car without sacrificing its quality or reliability. By sourcing parts from a breaker, you can save money while still getting high-quality OEM components. With a little creativity and research, you can create a unique and stylish car that reflects your personal taste.
